Cutting a 4 door down to a 2 door
Re: Cutting a 4 door down to a 2 door
The 6 cylinder class in oval track is steel body only and for CHD it has to be a matching engine as well.
Don't know if this will help.
Apologies if the showing of another forum's post is offensive to anybody.
Pieter.
Pieter.
?Waterhond wrote:Don't know if this will help.
Pieter.
The right thing is to move the door post back about 6 inches and then lengthen the front doors using a section of the rear doors and fill the rear gap with two donor rear doors ... I would do it ...
I am not even close to qualified to do this, but it has my interest and i wanna try so bad haha
The info i am battling to find is the correct final door size, and the distance to move the post.
when I worked at Ford and watched Bernie Mariner build the first Cortina bakkie prototype he used the Cortina 2 door station wagon and made no change to the front post! To move the front post will be a structural disaster!!Shaughn wrote:The info i am battling to find is the correct final door size, and the distance to move the post.
My suggestion to you is to search for a 2 door Cortina wagon to retain the correct chassis and just modify the rear end! If you really need to!!
Users browsing this forum: No registered users and 13 guests
