1965/66 Opel Rekord L Rally GMSA
Re: 1965/66 Opel Rekord L Rally GMSA
Found 2 speedos, incl. Shipping i wouldn't be cost 970 ZAR...
Checked the speedo cable all OK! It is the speedo that is making funny noises and vibration!v8-rekord wrote:Found 2 speedos, incl. Shipping i wouldn't be cost 970 ZAR...
I need to take the speedo out and test, it might be repairable!
I can scrape R1000 together! Lets communicate details on PM!
Johann
Not too difficult to remove!!Johann65 wrote:Checked the speedo cable all OK! It is the speedo that is making funny noises and vibration!
I need to take the speedo out and test, it might be repairable! Johann
Other option is to fit a GPS speedo!!
Here is my tribute to the Rekord "B" with its 8 month production run , Gordon and I's time at GMSA, The unique to SA McKinnon engine fitment. Starting to take shape!
Looking good Johann
Have started on the Speedo conversion. Will complete build on the new before shelving the current unit in one piece
Tachometer fits perfectly!!
Busy identifying each connection. The new unit has a separate earth connection for each gauge and light function!
The new unit will fit without having to cut or drill into dash! Going to take some time and planning!!
Instrument panel has been completed Now need to design the adapting frame that will hold the panel and the switches straight from the original panel! Minimal wiring changes! Using 6 ply marine wood!
That is looking good Johann.
Current cars:
1972 Opel Manta
1969 Opel GT
1980 Corvette
1971 Opel Kadett Coupe (Current Restomod build)
1966 Opel Kadett Coupe (Future restoration)
1948 Chevy 3600 Pickup
For Sale: 1971 GM Ranger
Ex: 1969 Opel Kadett Coupe, 1959 Opel Rekord P1
1972 Opel Manta
1969 Opel GT
1980 Corvette
Hope this another improvement! Have made the adaptor, needs to be finished off! Will fit on the exact fitting holes as the original speedo!! No Holes to be drilled!!! Adaptor will be sprayed To a suitable color!!VetteGP wrote:That is looking good Johann.
Switches will have a separate mounting made from the same material!
The Kadett "B" diff Ratio's
Final drive ratio‑Manual 4.1:1 (37/9); 1.9S, 3.67:1 (33/9)
Auto. 4.375:1 (35/8); 1.9S, 3.44:1 (31/9)
My Rekord has a 3.67 diff
Comments are Ok if they don't kill me!!
Surface prepared with Spot Putty and sanded! To be sprayed tomorrow!
Connectors fitted and each wire identified fit Pins to upper end of spacer and two locating holes at bottom edge!
