hei distributors for ford and chevy
- ● All adverts must include pictures and a price. This is not a bidding site.
- ● Please respond to enquiries, if you don't respond your add will be removed.
- ● Please change an item heading to SOLD when it is sold.
- ● Members are allowed 12 adverts per year to make sure the forum stays an enthusiast platform.
hi guys
ford and chevy hei distributors.brand new in the box.
1250.00 all inclusive
i cant seem to post pics
will try later
tim
will try later
tim
Re: hei distributors for ford and chevy
Hi Tim is this for 302W, 351W, 351C? Also is the coil in the cap as I have never used them?
Hi Tim
Can you please confirm if the Ford HEI distributor fits 302W SBF and is a direct replacement for the manual points and condensor, or is it a replacement for later models with electronic ignition (ignitor? Coil?)?
Forgive my ignorance - coil, points and condensor I understand - electronic ignition ECU etc is not something I have ever fiddled with.
Peter
Peter
hi there.the hei ignition system is an upgraded system from points and condensor to electronic ignition with built in coil.it is an all in one system.no need for external coil etc.
i have 2 that will fit a ford 302 motor as well as 3 that will do a 350 chevy sbc.i have 1 that will do ford 351 cleveland motor sent to me on error.
tx
tim
tx
tim
- HughMuller
can you please tell me model number and make so I can do a little reading up quickly
regards
hugh
regards
hugh
1971 Plymouth Cuda
1956 Ford F100
1971 Plymouth Cuda
1956 Ford F100
WE ORDERED THE PROCOMP.ONLY THE 351 C HAS A PROCOMP BOX
THE CHEVY IS A 6500 R AND THE FORD IS A KMJPE 3300.CHEV IS FROM SKIP WHITE PERFORMANCE AND THE FORD IS FROM KMJ RACING.HOPE THAT HELPS
ONLY 1 FORD 302 AND 1 CHEVY 350 DISTRIBUTOR LEFT
ALSO 1 351 C LEFT
HOPE THAT HELPS
TX
TIM
ALSO 1 351 C LEFT
HOPE THAT HELPS
TX
TIM
- HughMuller
Thanks Tim
Does help a lot
not going to work for my application but thanks
regards
Hugh
Does help a lot
regards
Hugh
1971 Plymouth Cuda
1956 Ford F100
1971 Plymouth Cuda
1956 Ford F100
HI GUYS
ONLY 1 CHEV 350 DISTRIBUTOR LEFT
TX
TIM
TX
TIM
The HEi is a very good dizzy.I use them in my Chev V8,V6,L6 and 4 cilender 2.5.And my Cadillac,Oldsmobile and even a Holden 308.
Works like a charm.
Works like a charm.
