*SOLD* Ford 390 FE.
Sell parts for muscle cars
  • ● All adverts must include pictures and a price. This is not a bidding site.
  • ● Please respond to enquiries, if you don't respond your add will be removed.
  • ● Please change an item heading to SOLD when it is sold.
  • ● Members are allowed 12 adverts per year to make sure the forum stays an enthusiast platform.
dom
*SOLD* Ford 390 FE.
Post by dom » Fri 23 Jun 2017, 15:16
FORD 390 FE Motor Galaxy, Mustang in pieces
Please read carefully to save you from the hassles I had with this build. I have:
390 block, bored to 4.112” according to a very experienced engine builder (they didn’t bore it), which resulted in 0.002” too big for the 0.0.60” pistons. Block sounds solid, ready to take the next overbore which will bring it to 4.13”. You should be able to source those pistons with the correct 390 pin heigt. In fact, one can even have pistons made for 4.112” bore – at a price. Or sleeve the block to a smaller piston.
4.11”, used pistons
crank which may need to be gound to fit the 0.10 bearings.
Heads which need new valves. 2-barrel cast iron intake
Assorted odds and ends to complete the motor.
R4.000 for above
New rings, 4.05 – 60 thou = 4.11” ($100)
new -10 main and rod bearings (Celvite) ($150)
R2.000
Gasket set
R1.500
For R7.500 you can take a chance and assemble the motor back as is. Without cam.
Aluminium 4-barrel intake manifold, divided plenum C6AE9425-E ($400+ in USA)
R4.000
Holley 4-barrel carb, probably 0-1850, condition unknown. I have a few parts to rebuild.
R2.000
Cam/lifter, timing and valve spring set Competition Cams K33-226-4, new ($450+, plus import)
R8.000
Total, discounted
R16.000
Nothing is as it seems!
dom
Re: Ford 390 FE, in pieces
Post by dom » Fri 23 Jun 2017, 15:17
Parts are in and around Cape Town
Dominik, 072 3424375
irpac
Post by irpac » Fri 23 Jun 2017, 22:31
Hi Dom, how much for me as I gave you the block,crank, pistons etc for free?
“Out of all the things I have lost,I miss my sense of humor the most.”
dom
Post by dom » Sun 25 Jun 2017, 08:45
Nice one, let's talk. I should have kept our block, even if it was only a 332 or 352..
Let's talk in the week.
Do you still have the 327/350 parts?
brennan67
Post by brennan67 » Sun 25 Jun 2017, 17:22
Hi,
I am looking for iron heads but with 3 bolt exhaust ports per cylinder. Also exhaust manifolds with same 3 bolt exhaust ports.
Would need to know the date codes if you have these parts?
brennan67
Post by brennan67 » Mon 26 Jun 2017, 06:46
Whilst on FE 390s... I am also looking for a C6 gearbox for a FE motor?
dom
Post by dom » Mon 26 Jun 2017, 15:56
MIne are 2 bolt exhausts, as are the exhaust manifolds. But the heads need oversize valves. Stems are worn.
I had approximately 20 sets of heads, and never a pair with 3 bolt exhausts. You may want to consider converting to the 2 bolt version.
brennan67
Post by brennan67 » Tue 27 Jun 2017, 06:46
Hi
No I need the 3 bolt version as those are the ones that are required on the 67/68 mustang as you cant get to the bolt heads due to the shock tower locations. Thanks for checking however.... I had to ask you never know what people have.. I will probably end up having to import from USA.
dom
Post by dom » Tue 27 Jun 2017, 15:16
I see... Just looked briefly at your project! Let me ask in Germany, too.
dom
Post by dom » Thu 20 Jul 2017, 07:38
How can I mark this "sold"?
I keep the parts and bring pistons from my next trip to Germany. Either to fit the bore as is, or standard to sleeve the block down.
