CHEVROLET KOMMANDO KICK-DOWN MEGANISM
I am still searching for a little mechanism,attached to the arm that works to the carb , and this little mechanism
pulls the cable which activates the kick down in the gearbox.
My 1971 Kommando has the 250 engine which is similar to those in the El Camino and Constantia of the time.
All help or information where I can search will be very helpful and appreciated.
Johan
Johan
JOHAN WEPENER
Re: CHEVROLET KOMMANDO KICK-DOWN MEGANISM
Hullo Johan,
Is dit kabel of meganies? Ek kan moontlik vir jou een in die hande kry! Gaan probeer kyk! Kan jy dalk 'n foto wys?
Hallo Johan
Dit werk met n meganisme vanaf die lang 'arm' wat na die vergasser gaan. Aan die meganisme is n
n kabel wat ratkas toe gaan.
Ek gaan so gou moontlik n foto plaas.
Baie dankie by voorbaat.
Groete
Johan
Groete
Johan
JOHAN WEPENER
Sal Moontlik kan help! Het met Piet gepraat! Groot Jaart nie ver weg nie!
Tersius gaan die foto plaas Johann, baie dankie.
Groete
Johan
Groete
Johan
JOHAN WEPENER
Ters.johan wepener wrote: ↑Sat 18 Nov 2017, 16:10Tersius gaan die foto plaas Johann, baie dankie.
Groete
Johan
Aan die bokant is die lang 'arm' wat deurloop na die vergasser.Net ongeveer waar die 'arm' verby die 'brakebooster'
loop is die' kickdown' meganisme.Die klein arm is daar maar n konneksie verder af is nie daar nie.
Ek vertrou dat dit sin maak Johann, baie dankie.
JOHAN WEPENER
See the picture Ters Posted,
Hullo Kavesh, The Part That Johan Wepener is looking for is can be seen on your dad's Chev! Can you Take a photo please. I can look for or make one!
It is the kick down rod from the throttle lever down to the carb! The rod is adjustable! has clip-on fittings similar to the first one your left!
