camaro gen2 diff
Viper Cape
camaro gen2 diff
Post by Viper Cape » Sat 01 Jan 2011, 14:32
Hi there looking for a good limited slip diff for camaro 74. 3,73/4,1 thanx Paul 0824581580
Gunter
Re: camaro gen2 diff
Post by Gunter » Sun 02 Jan 2011, 06:48
Me too!! i you happen to find 2,please let me know.....i have a '70 Camaro with a 400 Chevy in and without the L/slip
it just smokes the 1 rear tyre even trying to pull away 'normally'
RACECAR spelt backwards spells RACECAR.....
neresh
Post by neresh » Sun 02 Jan 2011, 08:19
Sooooo - you want to smoke both the rear,s ............
Gunter
Post by Gunter » Sun 02 Jan 2011, 13:04
O YES!!!! - its a pain that only the 1 rear tyre has a very HIGH wear rate :D
Viper Cape
Post by Viper Cape » Sun 02 Jan 2011, 14:08
I was told that a trans am unit will work. I was also told that you might have ls centres that one could possibly modify to fit? :roll:
Graeme
Post by Graeme » Sun 02 Jan 2011, 15:38
I'm thinking about pulling out my LS with 2.73 gears out of my buick and putting a normal 12 bolt with 3 something ratio.Even with a low ratio my buick runs 2 black stripes anywhere with ease but the problem is I get very bad hop when cornering.
I have one anti hop bracket but need another one.The nice thing about an LS is when you turn a corner and floor it the ass slides and it looks good
Friends don't let friends drive JUNK.
Viper Cape
Post by Viper Cape » Sun 02 Jan 2011, 20:31
Is it.going to be for.sale? If so let me know how much. Thanx
Graeme
Post by Graeme » Sun 02 Jan 2011, 21:15
If it goes,I'll let you know.it's a 12 bolt GM stock LS diff.just want to check my options first as I might just keep it in and up the ratio a bit.
Viper Cape
Post by Viper Cape » Sun 02 Jan 2011, 21:27
Cool will apreciate it if you kept me in mind if you decide to let it go ;)
