new generation v8s
GRUNTY
new generation v8s
Post by GRUNTY » Mon 05 Jan 2009, 22:26
Hi guys,has anybody looked into the Lexus v8 motor.Ihad the pleasure of seeing the heads off a motor. The combustion chamber and flat top pistons look like a modern superbike motor with valves and ports to suit .Is this where we are headed.Wots the weight like? Ally block and heads look good.So does intake.Some info would be nice guys.Cheers,
Grunty.
Gunter
Re: new generation v8s
Post by Gunter » Mon 05 Jan 2009, 22:41
exactly 100 pounds lighter than a Small Block Chevy....
RACECAR spelt backwards spells RACECAR.....
madrx
Post by madrx » Fri 09 Jan 2009, 07:10
Hi Grunty,I am new to this forum and ex SA living in New Zealand for about 9 years now.The use of the Lexus v8 is big here from ditrtrack,drags,curcuit,street,etc.The motors are super reliable.Some of the guys I deal with in the motor trade use these motors.One has just been fitted to a boat and the tow vechile is a Hilux Surf fitted with a V8 Lexus.You can get good power if you spend the money but i have seen supercharged and even twin turbo convertions.Power ranges from 450hp normal aspirated to about 850hp for a twin turbo setup.It all depends on the funds.
FPT
Post by FPT » Fri 09 Jan 2009, 07:55
Hi All
Two of my friends are currently using Lexus motors, one in a Jeep and the other in a Colt bakkie. The power on these things for the price is unbelievable so is the fuel consumption. The guy with the bakkie gets in the region of 15km/l at a average speed of 130 km/h. None of them have been modified and power is running in the 200 kw region. Reliability is apparently also out of this world.
This could defenately be an option for a modified beast and R 10k puchase price make sense.
Greetings
André
FairmontGT
Site Admin
Post by FairmontGT » Sun 11 Jan 2009, 18:39
Wow interesting stuff guys, how difficult is it to fit one of these newer engines to an older car?
madrx
Post by madrx » Mon 12 Jan 2009, 06:14
Hi,you get different type motors,front centre and rear sump.The motors are really compact.There are different headers as well .The most commanly used one is called the log style headers.One of my mates has one of these motors in his 80s Corolla.He is running a 21R box and the motor and box fits without firewall mods.The bonnet shuts normal and the car looks standard .I will try to get some pics.
madrx
Post by madrx » Mon 12 Jan 2009, 09:06
Pics of a motor in a Hilux
madrx
Post by madrx » Mon 12 Jan 2009, 09:07
some more
henryk
Post by henryk » Tue 13 Jan 2009, 09:05
Hi
Friend of ours is busy installing a Lexus V8 into an Opel Manta GTE (U K Import)
Gearbox is Toyota 21R.
We are however unsure of how to run the electronics/ignition.
It has been mentioned that some of the aftermarket companies like Dictator sell a pre programmed system to allow you to start and run the vehicle and then have it dyno'd properly afterwards.
Anyone have any experience with this?
Any other advice will be appreciated.
Henry
Escort's Forever !
madrx
Post by madrx » Tue 13 Jan 2009, 09:29
Hi,the guys over here normally use the factory wiring loom and sometimes modify the factory ECU.You can use aftermarket management and start from scratch, it is just the cost.There should be guys in SA that would have a system to do the job.It will be costly to get a system from overseas.
