You didn’t post the Perana tag.
I can’t be certain, as I don’t have the decode info for Granada’s, but I’ll hamper an educated guess at decoding the data plate you posted:
E = Source ~ Ford of Germany
X = Assembly ~ Neave plant (Port Elizabeth)
GF = Granada 4 door sedan
S = Year of Assembly ~ 1976
G = Month of Assembly ~ April
36213 = Serial Number
217121 = Sido number
Blank = Position for the engine code is blank, perhaps indicating it could be a Perana?
N = Floor shift 4 speed Manual
C = Diff ratio code (don’t have that info, and this is usually a numeric code, kinda strange)
Trim codes
P = Parchment Vinyl Roof
0 = Monotone
G = Tan interior
A = Metallic paint
0 = Monotone
5 = Burnt Gold (perhaps “Fern”, if it used an older Ford coding convention)
Not sure if this will align with what is there, there seems to be some Ghia trim pieces, wood door trim and dash, earlier Consul grille, the interior might be recovered, the patterns seem off, not sure if you can see any evidence of a vinyl roof…
From the data tag, I think it should look more like this car:
http://africanmusclecars.com/forum/view ... f=9&t=3007
