Electrical and Ignition.
Post by ters » Tue 13 Oct 2015, 18:44
Post all tips/tutorials here.
JayceLane
Re: Electrical and Ignition.
Post by JayceLane » Tue 17 Nov 2015, 10:17
Slant 6 distributor
If for some reason you have had to pull your distributor and put a replacement it from another car, chances are its not going to be set right for your engine.
The distributor gear, has 13 teeth, each representing 27' of movement. So if you run out of advance or retard when trying to adjust, and moving the gear one notch up or down, still causes you to overshoot, loosen the screw at the bottom of distributor and move to centre, then you should have enough adjustment.
If you like me, had accidentally moved the crankshaft before fitting the distributor, make sure cylinder 1 is at TDC (Top Dead Centre) and timing mark lines up. Then install distributor so that rotor is pointing to around about 4 o'clock or over the vacuum pot.
If you have NO idea what I am talking about, PM me. :lol:
No school like old school
www.jayces-classics-pares.com
Moering Tool
Post by Moering Tool » Wed 18 Nov 2015, 07:54
Ticking noise from dizzy?
Check it out in the pitch dark while the engine is running.
(Courtesy of Ters! :mrgreen: )
Users browsing this forum: No registered users and 4 guests
