Help with holley
Shaunp
Help with holley
Post by Shaunp » Fri 13 Nov 2015, 16:22
Hi muscle guys. Hope all is well. I have a holley 4 barrel. Was testing it but I have a problem, hoping you can help. I installed the fuel line directly to the carb without the regulator. Fuel is coming out the bolt on top of where the vacuum hose for the dizzy goes an a lot a fuel is coming out the two tubes when the air filter goes.
Magic happens.
colin davids
Re: Help with holley
Post by colin davids » Fri 13 Nov 2015, 16:49
Hi Shaun. If you are running a regulator then I assume you have a holley blue pump rather than the red. Without the regulator the blue pump will push 13 psi. Way too high for the holley needle and seats. That's why its pushing fuel out of the bowl vent. A holley likes 6 to 7 psi so set your regulator there and your problem will be solved.
FORD CAPRI PERANA NO. 66
FORD CAPRI V8 DRAG CAR
FORD SIERRA XR8
FORD CORTINA 3.0 S W/CHEVY V8
BMW E30 W/ FORD 347 STROKER
SUZUKI GSXR 1000
Shaunp
Post by Shaunp » Fri 13 Nov 2015, 19:37
Thank you Colin. I'm planning on running it on a sierra irs. Any idea if the xr6 fuel pump and regulator will work properly
Magic happens.
hitlers revenge
Post by hitlers revenge » Tue 17 Nov 2015, 14:08
Are there different Holley 4 barrels?
And if so, how do you know which one you have.
Where can one buy a regulator?
Post by RASSIE » Wed 18 Nov 2015, 08:17
There are 100's of Holley's. They got list numbers. List 1850 is a 600cfm.
hanov0
Post by hanov0 » Wed 18 Nov 2015, 12:53
Shaunp wrote:Thank you Colin. I'm planning on running it on a sierra irs. Any idea if the xr6 fuel pump and regulator will work properly
It will work as long as its of the carbed XR6
What size holley are you planning on using?
Hano'
hitlers revenge
Post by hitlers revenge » Wed 18 Nov 2015, 13:48
Thanks Rassie
Where do I start looking for numbers?
Shaunp
Post by Shaunp » Wed 18 Nov 2015, 16:14
Thanks Hano. Looking at a 450
Magic happens.
Post by ters » Wed 18 Nov 2015, 16:32
hitlers revenge wrote:Thanks Rassie
List of all Holley's, CFM's and service kit number: http://documents.holley.com/techlibrary ... isting.pdf
Shaunp
Post by Shaunp » Wed 18 Nov 2015, 20:24
Awesome info
Magic happens.
