Mustang Exhaust
Mustang Sally
Mustang Exhaust
Post by Mustang Sally » Fri 22 Jan 2016, 09:05
Hi Guys, pick some brains please?
On the Mustang build we've gone for a 4 link rear suspension. This has resulted in the space between the diff, body and fuel tank being quite restricted on the left side of the car (the mobile side of the 4 link). It leaves me with a couple of options for routing the exhaust: 1. Make the tight squeeze over the diff, 2. Stop the exhaust before the diff (not very keen on this one!), 3. Bring it out as side pipes.
Any other suggestions or experience with this would be appreciated, thanks.
68 Mustang Coupe RHD
62 Corvette
67 Dodge Monaco
52 Chevy 3100 496 project
356 Replica
76 AMC Hornet
62 Mk2 Convertible Jag project
73 Mk3 Cortina V6
Hi, my name is Neels and I have a problem... :lol:
moparmad
Re: Mustang Exhaust
Post by moparmad » Fri 22 Jan 2016, 12:53
Well the best solution will be before the diff, if you squeeze it over the diff there might be a restriction and loss of power, although it will be very little the worst will be klonking and knocking noise if you go over a hump or dip, that will destroy the enjoyment witch a drive in a car like that will give.
Just in front of the rears can work, but when not done proper it can look out of place and spoil it more. If it was a Shelby look a like well the side kick out in the side skirts look awesome.
What size pipe will you be running and the clearance gaps between diff and body?
FPT
Re: Mustang Exhaust
Post by FPT » Fri 22 Jan 2016, 21:40
Side pipes just before the wheels with a big flat non bling look could work.
Greetings
André
hanov0
Re: Mustang Exhaust
Post by hanov0 » Sat 23 Jan 2016, 11:04
Something like this?
Its there but not.
Hano'
FPT
Re: Mustang Exhaust
Post by FPT » Sat 23 Jan 2016, 12:58
Thats what I was thinking Hano.
Greetings
André
Re: Mustang Exhaust
Post by IndianaJones » Sat 23 Jan 2016, 13:10
Some ideas for over and under the diff...
Mustang Sally
Re: Mustang Exhaust
Post by Mustang Sally » Mon 25 Jan 2016, 11:06
Wow! Thanks Indy, these pics give oodles of options!
Thanks Hano and Andre - I really like the "there but not there" option.
MM, looking at running 63mm pipes but maybe upping to 70's if space will allow.
Thanks for all the input guys, much appreciated!
62 Corvette
67 Dodge Monaco
356 Replica
76 AMC Hornet
73 Mk3 Cortina V6
