Essex V6 advice ...
Posted: Sat 09 Jun 2018, 18:48
This one for all the essex fundis ...
So pulling heads after head gasket failure I see circular indentations on piston
- size and location matches intake valve
- have it on #1, #3, #4 and number #6 pistons. Slight mark on #2. Was not there a year ago
Quite shiny as well - thru the carbon, so must have happened recently. Any suggestions as to cause and possible remedies?
Have checked the cam timing. Was my first check. No problems on valves. Seated nicely away from piston.
Sticky valves - how to check? Same with valve springs.
Thanx in advance.
Thanx in advance.
