Low vacuum
zyl.3157
Low vacuum
Post by zyl.3157 » Wed 27 Mar 2019, 07:59
Good day gents. I recently rebuild my sbc 350 and after that my brakes was crappy. Found that my vacuum is like 0.4 after the cam change. If I drive 120 car brakes semmi ok. What is the selotion. Was told to fit electric vacuum pump kit. Will this work. Thx
Re: Low vacuum
Post by jlebenon » Wed 27 Mar 2019, 18:02
What's the cam specs and what is the timing set at ?
Re: Low vacuum
Post by jlebenon » Wed 27 Mar 2019, 18:06
There's a few different things to check before you use a vacuum pump ... Any of the gaskets or hoses could cause low vacuum easily
