R59 Governmental Gross Stupidity!!
The Highway Roads Maintenance have just proved their incompetence and stupidity that has cost the motorist Thousands of Rands
Where have you seen that you paint all the road lined and do a great Job and the following day or so destroy all the paint work by spraying the road with tar, No warning signs to the public leaving them with the mess!! This all on the R59 in the Henley area! Look at my Wife's Car!!
Fortunately it is coming off by painting the tar with soft Margerine and letting it stand see how the margerine absorbs the tar and the dogs taking a lick!! It then washes off with a strong BioClassic solution. Rear end completed. Lot of work Monday!!
- damagecontrol
Re: R59 Governmental Gross Stupidity!!
That's BULLSH!T....!!!
I would drive straight to the municipality and let them clean it!!
You, you, and you: Panic. The rest of you, come with me.
89' Mercedes Benz 230e
....erode confidence in the enemy and cause the opposing forces to be left not knowing where the devastation is coming from....
Hi Johann,
I have seen worst than that maar ek sal ook my moer strip.
The local Car wash guy took petrol and it came off but using alot of new clean rags.
+1damagecontrol wrote:That's BULLSH!T....!!!
Parafien will do the job.
They did the same spray job on the N14 between Krugersdorp and Pretoria over the last 2 weeks - ball's up of epic proportion. Then they also do it at peak time in the morning and evening. Paraffin removes most of it but in my case still leaves a stain - maybe depens on the type of paint on the car.
Hullo All,
The soft margerine is doing a fantastic Job! It changed the tar to molasses!!
Washed off with a solution of Detergent!! No smell of parafin No extra rags.
You actually see the margerine change colour!!
Just the left side to do then complete
This was done early in the morning with no warning sign!!!Hubcap wrote:They did the same spray job on the N14 between Krugersdorp and Pretoria over the last 2 weeks - ball's up of epic proportion. Then they also do it at peak time in the morning and evening. Paraffin removes most of it but in my case still leaves a stain - maybe depens on the type of paint on the car.
Here is the job done sofar:
Note the soft Tar!! Final side to be done!!
How do you get that rubbish out inside the wheels arches? With the plastic covers on new cars that rubbish will be sitting inside the aches!!!
Greetings
André
André
Users browsing this forum: No registered users and 16 guests
