Is anyone willing to sell the V6?
12/70 and the number is 52? There is something a bit suspect here, my car is number 58 and its 10/70......kiwicapri wrote:Hi John.
My reserach tells me that the "R" pack options were available as "options" earlier than 1972. The "R" pack Perana was available as a complete car in 72.
Also, in 72, all uk based Capris, from the lowest 1600, up to and including all V6 variants, were produced with a power bulge bonnet.
You maybe correct in asuming that Ford ZA, or BG may have run out of the power bulg bonnets, or they simply used up the 1600 shells etc.I don't know, as it seems that Ford ZA have no history of them.
I have a genuine 1970 Perana. (It was imported to NZ about 2 years ago, by the previous owner, dismanteled for restoration, but never got off the ground). We discovered it had been converted to an auto, from a manual. It has all the correct tags etc, and stamped block. BG0052 12/70 "R" pack, complete with quarts iodine diving lights, rear aero foil and louver. The front air dam/spoiler has vanished, but the outline and holes for mounting it are still there. I beleive the rear wing to be a Falcon GT item from the XY, or a Mustang item of the same era.Again, why would you go to all the trouble of producing a small number of parts,when you could by them in from the US or Aussie? Same with the drive shaft-XW/XY Falcon 28 spline shortened? I think so.
At some stage, some ignorant so, and so, replaced the back end with a later falcon unit, that has had a 4 stud conversion, and no LSD, but the correct ratio. It has also never been set up correctly, as when we took the lid off the bac, the gears are only partily meshing, and the marker dye, is still on some faces, where there is no contact. in fact, it binds when you turn it by hand. The a=other stupid part is, they have the backing plates on the wrong sides, and monted 90 degrees around from where they should be!
So, i need to find out what the diff origonaly came out of, to be shortened in the first place.No one in there right mind, would have Borg Warner completly re design a diff, for a homoligation special. could it have been out of a 69 Fairlaine?
One other thing that has been debated in the past, is the need to remove the battery tray. the 1970 and 71 inner wings are different. 1970 has no indentation where the battery tray is. It is the same inner wing as a 1600.
Hey, at the end of the day, i am seeking info, and not trying to be a know all, but it seems that the mystery, is not as mystical as it may seem. Just some healthy research, and a bit of thought.
I know Duncan well, have assited him, and followed the project with him.It is well underway, but some time off completion.
Regards to all, and if any one has a pair of genuine tail lights/Capri/Escort Hella ZA/Ford ZA,then please let me know, it is one thing we are both looking for.
Wayne
12 - 70 for BG 52 throws out the sequence with regards build date as far as I can figure the little bit I know.ZA Perana wrote:12/70 and the number is 52? There is something a bit suspect here, my car is number 58 and its 10/70......kiwicapri wrote: I have a genuine 1970 Perana. (It was imported to NZ about 2 years ago, by the previous owner, dismanteled for restoration, but never got off the ground). We discovered it had been converted to an auto, from a manual. It has all the correct tags etc, and stamped block. BG0052 12/70 "R" pack, complete with quarts iodine diving lights, rear aero foil and louver. The front air dam/spoiler has vanished, but the outline and holes for mounting it are still there. I beleive the rear wing to be a Falcon GT item from the XY, or a Mustang item of the same era.Again, why would you go to all the trouble of producing a small number of parts,when you could by them in from the US or Aussie?
Wayne
Aside from that did the car orginate from Cape Town by any chance?
