1962 desoto diplomat
The Russ
Post by The Russ » Sat 26 May 2012, 22:54
hi guys i moved my restoration job to the restoration section.
started stripping and in the process of sanding down the car for repairs and painting.
When life gives u lemons turn it into a lemon worth driving.
When doing right is wrong, then go left.
When u stand alone, it means that silent fart realy smells...
The Russ
Re: 1962 desoto diplomat
Post by The Russ » Sat 26 May 2012, 22:56
can any one suggest a way to remove rust and scales of a car? :?:
Bearhawke
Post by Bearhawke » Sun 27 May 2012, 00:07
The guys over on http://www.1962to1965mopar.ornocar.com/welcome.html would be very interested as well as http://www.allpar.com/ because any 1962+ 'DeSoto' is newsworthy. The last year for DeSoto in the USA was 1961. :)
Bearhawke in Az, USA
Garage
Post by Garage » Sun 27 May 2012, 05:49
The Russ wrote:can any one suggest a way to remove rust and scales of a car? :?:
Assuming you want to do this yourself and not go the 'blasting route.
I use a product called 'De-rust" from Laser Chemicals here in CPT. It is just a phosphoric acid based rust remover.
Phosphoric removes the rust without affecting good metal.
In tougher situations hydrochloric acid (pool acid) will work much quicker but etas good metal too. Not a big problem if you are careful but it needs to be neutralised (bicarb or soda ash dissolved in water).
Many 'metal-prep' products are phosphoric based and you don't need to be so religious in getting it off before paint, although some etch primers are incompatible with this
Both will require manual scrubbing too - wire brush/scotch-brite pads.
Barry
Metalshaping courses, Replacement panels, Full Builds, General Fabrication.
http://www.facebook.com/pages/The-Garag ... 2857822743
The Russ
Post by The Russ » Sun 27 May 2012, 09:07
thanks garage i`ll give a try. :)
The Russ
Post by The Russ » Fri 27 Sep 2013, 18:42
update on my restoration. primed and ready for paint.
Post by ters » Fri 27 Sep 2013, 19:05
Looking good Russ!! Keep updating please.
The Russ
Post by The Russ » Fri 27 Sep 2013, 19:24
started upholstery during grumpy weather and late nights. lucky for me the guy who rents the open space in our building has all the machines i need to tackle the upholstery project. being a DIY guy and having sowing experience (mother having no girls to teach) he lets me work with his machines free of charge. :mrgreen: starting seats this weekend if weather is nasty. :roll:
all my goodies
a time consuming process
the art of sightless needle work
almost there
added look
rear door
front door
door panels complete just need to fit. front and rear panel.
Post by ZA Perana » Sun 29 Sep 2013, 09:11
Really impressive work on the upholstery!
marnus
Post by marnus » Sun 29 Sep 2013, 09:33
what happend to the second axle on the caravan?? :D
