1965/66 Opel Rekord L Rally GMSA
Johann65
Re: 1965/66 Opel Rekord L Rally GMSA
Post by Johann65 » Wed 08 Feb 2017, 23:35
After the first burnishing. Needs a lot more!!! :mrgreen:
Next wheel alignment, pulling to right! 8O
Post by RASSIE » Thu 09 Feb 2017, 07:08
Looking very good Uncle Johann. Let me think of the Chevy 2.
Do you need more paint for the rocker cover? :D
Johann65
Post by Johann65 » Thu 09 Feb 2017, 09:11
Thanks for the offer Rassie! I still have two cans on my shelf! :D Want to prepare a soap solution and brush the engine bay with it! 8O Then WAP the bay! 8O
Some interesting info! 8O
The Rekord A that appeared in March 1963 was a robust response to the success of the Ford Taunus 17M.[1] The design of the new Rekord sedan came not from Germany but from the General Motors Technical Center in Warren, Michigan, and was inspired by the successful Chevrolet II
I can't find the correct wheel alignment specifications for the Rekord B and have been using the Chevy II data from the beginning![/size] :mrgreen:
v8-rekord
Post by v8-rekord » Thu 16 Feb 2017, 06:33
Camber : 1/2° - 1°1/2 (First Series)
1°1/4 - 1°3/4 (Second Series)
Trailing: 1°1/2 - 2°
Toe: 1 - 3 mm
Track difference angle 1 1/4 by the impact of the curve outside from 20 degrees.
That was i found on the web in the Opel Rekord Forum.
Johann65
Post by Johann65 » Thu 16 Feb 2017, 09:09
v8-rekord wrote:Camber : 1/2° - 1°1/2 (First Series)
Toe: 1 - 3 mm
Thanks! Much appreciated. Would like the site address if you have?
Johann
Johann65
Post by Johann65 » Thu 16 Feb 2017, 21:15
Found this in my search for data!
Facts: 1963-1966 Opel Rekord
Some facts:
• This Rekord A model came out in March of 1963 to replace the previous Rekord P2 and initially it was named Olympia Rekord R3 but it was quickly changed to A (later Rekord's would be called B and C).
• The 1.5 and 1.7 engines were based on the Opel Olympia engine from 1937 and the Rekord A would be the last model to use those engines. They were developed up to 55, 60 and 67 HP.
• The line-up was a repeat of the Rekord P2, 2-door and 4-door sedan, 2-door coupé, 2-door caravan and 2-door delivery van. A cabrio version was also available in Germany.
• The Rekord L-6 was launched one year later in March 1964 and used the 100HP 2.6 litre inline 6 cilinder engine from the larger Opel Kapitan and was Opel's first 12 Volt engine. This engine was developed from the 1937 Opel Super6.
• 4 drum brakes were standard and front disk brakes were available as an extra.
• The Rekord "B" was released in July of 1965 and produced for less than a year. This model was just to prepare the stage for the Rekord C that was being finalized at the time.
• Besides the small exterior facelift (headlights, grille, rear end and tail lights), the Rekord B received the new four 4 cylinder CIH (cam in head) engines (1500, 1700 S, 1900 S) that would be used in further generations up until 1986. The rear transaxle was also wider which helped handeling and it would be the last Opel to use leaf springs.
• The round tail lights on the Rekord B would later be used on the Manta and GT.
• 887,304 Record A's were manufactured from March 1963 to August 1965.
• 296,000 Record B's were manufactured from August 1965 to July 1966.
v8-rekord
Post by v8-rekord » Fri 17 Feb 2017, 07:32
I got it from this Forum: http://www.rekord-p2-forum.de/?s=47b7ac ... 1476e4a19f.
I know in the Netherlands is a Rekord-B Forum.... look at Google or i will do it for you...
Her something for you, it's for the Rekord-C but maybe it will help you.... http://graf-vlad.de/inhalt/alte_kisten/ ... lt-01.html
http://cokebottle-design.de/commodore_a ... werte.html
P.S: if you need some Parts from Germany let me know.....
Johann65
Post by Johann65 » Fri 17 Feb 2017, 17:10
v8-rekord wrote: P.S: if you need some Parts from Germany let me know.....
Thanks for the offer! I would like to fit a Kph speedo but it will be outside my budget! I am looking to fit a Universal gauge as a add-on! They are not expensive!8O
Thanks for the websites! I can help myself regarding Deutch! :mrgreen: Am picking a lot of data that I was not aware of! 8O
It appears that the Rekord "B" L model only were fitted with the 130MpH speedo and the other models with the 110Mph speedo 8O
Found a second Opel Rekord L with the same 130Mph speedo in the Cape! 8O
Johann65
Post by Johann65 » Fri 17 Feb 2017, 21:10
The engine clean-up is going well! Removed the hose clamp caps! too much clutter! :mrgreen:
VetteGP
Post by VetteGP » Sat 18 Feb 2017, 06:01
Looking good Johann
Current cars:
1972 Opel Manta
1969 Opel GT
1980 Corvette
1971 Opel Kadett Coupe (Current Restomod build)
1966 Opel Kadett Coupe (Future restoration)
1948 Chevy 3600 Pickup
For Sale: 1971 GM Ranger
Ex: 1969 Opel Kadett Coupe, 1959 Opel Rekord P1
Users browsing this forum: No registered users and 12 guests
