Page 1 of 3
1971 Opel Kadett build
Posted: Sun 24 Jul 2016, 16:55
by VetteGP
Hi All,
I am planning to start a build on a 1971 Opel Kadett Coupe. The car will be arriving from Cape Town on Thursday (if no delays on transport). I will post photos of the car when it arrives.
I would like to ask forum members for some advise.
I am going to install a Superboss 2l engine and I have been trying to find out what is the best gearbox to use for the rear wheel drive conversion with this engine. I would like to use a 5 speed box.
Has anyone done this before or has information regarding such a conversion in SA?
Gareth
Re: 1971 Opel Kadett build
Posted: Sun 24 Jul 2016, 17:14
by Can-Am ZN
You can perhaps speak to the Lotus 7 guys who have used the 20XE motor in their RWD set-up.
Good luck with the conversion...that thing's gonna go like stink!
Posted: Sun 24 Jul 2016, 17:32
by zahistorics
Almost any European engine Opel/Vauhall RWD box should fit.
Posted: Sun 24 Jul 2016, 17:41
by bmwmaniac
and don't forget the OPEL powered ISUZU bakkies all have RWD 5 speeds
Posted: Sun 24 Jul 2016, 17:50
by IndianaJones
You have multiple options.
Easiest is the Opel R25 / Getrag 240 gearbox out of an Opel Rekord.
You can also use the Toyota "21R", the Formula Supercars guys use either this or the Getrag gearbox.
http://www.formulasupercars.co.za/about.html
I believe most Lotus 7 or Locost guys use the Ford Type 9 gearbox.
http://www.sbdev.co.uk/SBD%20Motorsport%20Display.htm
Posted: Sun 24 Jul 2016, 18:08
by Can-Am ZN
You guys are sharp...when in doubt, ask the AMC fellas
Posted: Sun 24 Jul 2016, 18:16
by VetteGP
Thanks Everyone for the responses.
Appreciated.
I will check these out.
Posted: Sun 24 Jul 2016, 18:43
by Gunter
Claude Williams race the ex Kosie Swanepoel one..... think he is using the 21R Toyota box, you would need to modify the sump. Suspension and brakes would need an upgrade from the stock stuff - but once done,you will have a nice 'toy'
Posted: Fri 29 Jul 2016, 07:46
by VetteGP
After quite a few delays, weather, jackknifed trucks blocking the way, bust water pipes, the Kadett will arrive today.
Can't wait to get cracking on this project.
Posted: Fri 29 Jul 2016, 18:21
by VetteGP
Hear she is.
