Ford Falcon XH Ute
Racer-X
Re: Ford Falcon XH Ute
Post by Racer-X » Fri 23 Sep 2016, 20:36
Inside of diff:
Diff tag:
Sent from my SM-G920F using Tapatalk
Post by IndianaJones » Sat 24 Sep 2016, 18:55
Racer-X
Post by Racer-X » Sat 24 Sep 2016, 18:59
Thanks. I read that the other day. So it seems I have a non ls Lsd. Pity. As it spins easily on grass. I wonder if it's feasible to fit a local diff with diff lock?
Post by IndianaJones » Sat 24 Sep 2016, 19:06
I'm by no means a diff expert, but I wonder if it might be feasible to drill and tap a hole in the sealed-off LS unit, drain the fluid, perhaps flush it, fill with the correct stuff, and screw shut with a plug or something.
Racer-X
Post by Racer-X » Sat 24 Sep 2016, 19:28
IndianaJones wrote:I'm by no means a diff expert, but I wonder if it might be feasible to drill and tap a hole in the sealed-off LS unit, drain the fluid, perhaps flush it, fill with the correct stuff, and screw shut with a plug or something.
Hmm, that sounds reasonable.
I must investigate
hanov0
Post by hanov0 » Sun 25 Sep 2016, 07:59
Hi Racer x
I also got an XH , the 4.0 GLI 5 speed.
Love this car and its ability to move huge loads!
Going to go look at an XR6 this week for my brother in law.
Hano'
Racer-X
Post by Racer-X » Sun 25 Sep 2016, 08:30
hanov0 wrote:Hi Racer x
Nice rims!
Are they 17 inch ?
What size are the 2 fuel tanks?
What fuel consumption do you get?
Sent from my iPad using Tapatalk
hanov0
Post by hanov0 » Sun 25 Sep 2016, 08:57
Those are 19'' X5 rims.
On mine the second tank was taken out , but I do have it still.
Remaining tank is 60 liters as far as I know.
In town I get about 8km/l
open road about 11Km/l
But then I do have a heavy foot.
Hano'
Racer-X
Post by Racer-X » Sun 25 Sep 2016, 09:00
hanov0 wrote:Those are 19'' X5 rims.
The rims like great.
Ok, so BMW pcd is the same.
I assume then i have 2 60 litre tanks.
That consumption is not bad.
I assume mine will be a bit worse having an auto box.
hanov0
Post by hanov0 » Sun 25 Sep 2016, 09:37
No the Bmw is 5 x 120 , ford is 5 x 114 so needed adaptors to fit
and offset was out so it was quite a bit of trial and error to get the right thickness.
Front rims was narrowed th 7,5 inch to clear the upper control arms.
Hano'
