Ford sierra 302 con version
Pictures of your muscle car!
wanegofast
Re: Ford sierra 302 con version
Post by wanegofast » Tue 15 Sep 2015, 14:35
chevy or ford love them all hey
my converter is back had it stalled in process it seems that i have buckled my flex plate hens the vibration :oops:
wanegofast
Post by wanegofast » Tue 15 Sep 2015, 16:16
any one in the market for a new 154 tooth ring gear let me know lol
wanegofast
Post by wanegofast » Wed 25 Nov 2015, 08:20
:( :oops: :( vibration still there all gears P R N 1 2 D from idle all the way till it broke my starter out of the bell housing. now we start over any suggestion. seems like bendix vibrated forward and grabed on to flex plate. or started was running with engine but i do think i would have heard that??????
Mustang Sally
Post by Mustang Sally » Wed 25 Nov 2015, 09:08
Eina!! 8O 8O
68 Mustang Coupe RHD
62 Corvette
67 Dodge Monaco
52 Chevy 3100 496 project
356 Replica
76 AMC Hornet
62 Mk2 Convertible Jag project
73 Mk3 Cortina V6
Hi, my name is Neels and I have a problem... :lol:
wanegofast
Post by wanegofast » Wed 25 Nov 2015, 15:32
Mustang Sally what is happaning man any advice i need help guys
colin davids
Post by colin davids » Wed 25 Nov 2015, 16:47
If you bolt the flexplate onto the engine and then fit the torque converter on its own do you get any clearance between the t/c threads and the flex plate? If so then you either have a spigot bearing in the back of your crank or the t/c snout is too big for the crank. Once that is sorted you can fit the box and see if it goes flush against the block without tightening any bolts.Then you should check your damper. V8 sapphires came with 50 ounce dampers.If that is what youve got then your crank and damper dont match the 28 ounce flex plate.If your engine has a dipstick tube on the side of the block passenger side then its the later block and probably 50 ounce.28 ounce engines had it in the timing cover. Hard to diagnose without seeing the car but that should get you started.
FORD CAPRI PERANA NO. 66
FORD CAPRI V8 DRAG CAR
FORD SIERRA XR8
FORD CORTINA 3.0 S W/CHEVY V8
BMW E30 W/ FORD 347 STROKER
1970 MUSTANG MACH 1 MANUAL W/4V CLEVELAND
SUZUKI GSXR 1000
FORD SAPPHIRE 2 LITRE 16 VALVE TURBO
wanegofast
Post by wanegofast » Thu 26 Nov 2015, 12:55
hi Colin the crank has no bearing in it i am shore of that and made 10 times shore when installing box. the 2nd time around no force was used at all. the crank had a small burr or what looked like a tack (weld) where spigot locatesi had cleaned it out with sandpaper and fits nicely. my flexplate goes on quite tight though. the only thing i did not replace is damper but rubbers and all look fine on it. but hey Colin if you want to and if you are in cape town i have beer pop in i will accept any help or knowledge i can get.
Users browsing this forum: No registered users and 4 guests
