Ford sierra 302 con version
Re: Ford sierra 302 con version
ok so motor has been in and come out again i am getting a vibration from converter side has new 28oz flex plate and damper is fine. when bolting converter to flex it seem to bow the flex plate. what happening here could it be converter ???? this second time out now
ooooo i have made some improvements on the first test fit engine bay has been sprayed and dress up kit is there looking grate and sounds super awesome
- WAIMG_1.jpg (104.66 KiB) Viewed 4460 times
- IMG00087-20150704-1505.jpg (90.16 KiB) Viewed 4460 times
Is your convertor seated inside the box and the gearbox pump??
Before you bolt it onto your flex plate.
That is a very clean Sierra, and a sleeper with the 8 installed. Looks relatively standard, should bring loads of smiles to your face.
i would say yes listened for the 3 clunks when installing it in to the box this is very funny one as no one i have spoken to had ever come across this problem.
and yes Mojo sleeper is what i am going for leaving all decals standard. tried doing conversion as factory and standard as possible. xr8 crossmember and all
- ROBBINATOR
Hi there.......was there perhaps a manual gearbox attached to this motor previously??wanegofast wrote:ok so motor has been in and come out again i am getting a vibration from converter side has new 28oz flex plate and damper is fine. when bolting converter to flex it seem to bow the flex plate. what happening here could it be converter ???? this second time out now
Cheers........Robbie.
EXPERIENCE.....tells you that a Tomato is a fruit.
WISDOM....tells you that it does not go in a fruit salad.
GOOGLE....can help avoid your customer's car from burning out and then been summonsed to court.
+1ROBBINATOR wrote:Hi there.......was there perhaps a manual gearbox attached to this motor previously??wanegofast wrote:ok so motor has been in and come out again i am getting a vibration from converter side has new 28oz flex plate and damper is fine. when bolting converter to flex it seem to bow the flex plate. what happening here could it be converter ???? this second time out now
Checked to see if there is still a pilot bush or bearing in the crankshaft?
i took the flex plate and converter in to torque converter center to have checked out going to do a stall in the process then i know they are both right if i get the same problem after this i am going to be a bit stumped. then possibly crank?
hanov0 wrote:Looking good sofar, I have done the V8 in Sierra thing, now busy with a Sierra with straight six.
hi hano i am also inquisitive is it a BOWTIE maybe
well done there mate i like the idea u have some BOWTIE parts in a FORDwanegofast wrote:Hi gentleman
so i have been quite busy the last six months on my V8 conversion so this will be a update on how far i have come. just some back ground on car.
its a 85 sierra xr6 with original tilt and slide sunroof. just to put your minds at ease i am not doing a xr8 replica just a clean neat sierra with a v8.
info on motor and running gear
302b heads with chevy 1.95 and 1.6 valves and ported
all new internals 40 over pistons
parana intake
600 holley
dizzy with ignitor
morroso leads
xr8 branches
c4 gearbox
3.08 diff
sierra up grades done discbrakes at back and new spring all round aswell as origenal xr8 xmember.
motor almost done here with help from my dad Nicol and uncle Chris Gerber and my at that time 8month old boy Lian. here we have completed the monster day motor went in was not easy but got her in (blood sweat and tears and of course some big words) and a well deserved beer and smoke. motor in its final resting place there after came all the hard stuff connecting all parts to engine that gave me some gray hairs as it seemed to be 1 steps forward and 5 back but all has worked out so far radiator in fans on alternator dizzy.
i have come far now want to maybe start this weekend will update with pics soon its much more complete than the last pick above.
hope next one i can post a sound clip
let me know if you guys have some advice or input
cheers vir eers ouens
Users browsing this forum: No registered users and 23 guests
