1980 Pontiac Trans Am Turbo
Pictures of your muscle car!
pietpetoors
Re: 1980 Pontiac Trans Am Turbo
Post by pietpetoors » Mon 06 Feb 2017, 22:37
Update:
She was sanded down to bare metal. Body still very good, no rust and almost no body putty. Nice solid body.
Was then painted a thick white primer to see any marks which needed attention.
After that another primer and then the final coat.
Picard
Post by Picard » Tue 07 Feb 2017, 08:56
Looking good!
8)
pietpetoors
Post by pietpetoors » Sat 08 Apr 2017, 12:53
I am busy putting the pontiac back together.
On the firewal, between the two wipers, is this electric wire. I can see from the colour of it that it made a short circuit.
It was not connected to anything when I disassembled the vehicle.
Does anybody know what this is for?
Also the flap in the second picture, where does that go?
Wire?
Flap
maxman
Post by maxman » Sat 08 Apr 2017, 14:49
The flap looks like the fresh air/ recirculation flap for the air conditioning?
Sent from my SM-G935F using Tapatalk
'71 XW Fairmont GT (silver fox)
'96 Yamaha Vmax (muscle bike)
Picard
Post by Picard » Sat 08 Apr 2017, 15:24
Is the wire not for the aerial?
My Trans Am has the aerial built into the windscreen and the wire comes out the bottom.
The flap goes on the cowl. I think it recirculates fresh air from outside and is vacuum driven.
pietpetoors
Post by pietpetoors » Sat 08 Apr 2017, 17:25
Thanx, found the flap's spot. Will check out the arial.
What happened to the 301 forum, has it been down for long?
Picard
Post by Picard » Sat 08 Apr 2017, 18:17
pietpetoors wrote:Thanx, found the flap's spot. Will check out the arial.
Not sure. Normally just sit on the Trans Am Country forums.
pietpetoors
Post by pietpetoors » Sat 08 Apr 2017, 19:22
How is your trans am going, did you finish her?
What tyres do you have on your's? The tyres on mine is perished, so I need to fit new tyres. Not sure if I must get something wit white lettering on.
pietpetoors
Post by pietpetoors » Sat 08 Apr 2017, 19:25
O ja Marco, another thing I wanted to ask, do you know of a place in rsa where I can get those plastic clips one use for the chrome beadings for the doors? I need one.
Picard
Post by Picard » Sun 09 Apr 2017, 17:05
pietpetoors wrote:O ja Marco, another thing I wanted to ask, do you know of a place in rsa where I can get those plastic clips one use for the chrome beadings for the doors? I need one.
Mmm, not sure which clips you are referring to. Wurth normally stock loads of different clips locally. FBodywarehouse.com may also have what you're looking for.
Mine is back on the road. Still a few things to sort out and finish up, but been driving her around and slowly sorting out small things.
I've got 17's on. Toyo Proxes 255's all round.
