The last piece of that particular puzzle was getting a steering column in place. OEM Cortina column is integral part of the steering box which I removed. One could alter it with some modifications to work with a steering rack, but since I had the column that came out of the Taunus and I found on offering it up to the car that it just about fitted straight in with minimal changes required, I went that way. Originally it comes off a MkIV or V Cortina. It had been altered to extend further away from the dash already, so much time and effort safe. Some minor adjustments to the mounting and new holes drilled under the dash sorted out its location there.
At this time (because they have to be positioned together) I also worked on getting a pedal box in the car. The OEM parts were in sad state and pedal missing. It also would not work with the master cylinders I wanted to use, nor the cable for throttle operation. These Cortina's used a system of levers and links to the carb, no cable. So the whole pedal box went and along with the steering column, I started massaging the whole pedal box from the Taunus in there. It took some trimming here and there, also significant modification of the firewall's holes and locating bolts, but it is in, works with the steering column. Not many pics, but can be seen on some of he pics to follow.
Finally it was time to put a wheel on the car to see how it would work with the mudguard, where the flare needs to be , how high and so on.
- Photo0846.jpg (56.52 KiB) Viewed 3646 times
At the ride height and width of the wheel, it fouled completely, so pictured here the arch already has its lip trim off. The wheel is also lowered to get it clear for work on the arch.
I wanted to try and copy the original car's flare shape as close as I can. The photographs I do have only give me an idea though, not a clear picture. Also, I believe those original arches were wider than what we are allowed today by our rules (nominal 2" or 50mm wider than std). So some compromises has to be made.
A popular flare here at the moment is to buy a set of Golf 1 front fenders (they're cheap enough) and then cut the flare out to weld onto the car to be flared. Another way is to buy one of the ready made glassfibre flares that guys sell. They are 50mm wide and look period correct too. Neither of those options would work for me (size and shape) and in any case I am not a fan of those Golf arches.
So I decided to make my own flares again, similar to what I did on the Capri. It takes a while, lots of work and takes time to finish off properly. But you do get to make them exactly like you want them. There are other ways to skin this cat, what I show here is my preferred way.
It takes some marking out and measuring and marking, lots of it.
- Photo0847.jpg (68.62 KiB) Viewed 3646 times
I had a cardboard template around this lot, marking and recording dimensions. This is important, because shaping this one flare is tough enough, then you have to go and make its exact mirror image on the other side. So anything to help you transfer the shape and dimensions to that side helps.
- Photo0848.jpg (49.67 KiB) Viewed 3646 times
This pic above is the other side, the repaired mudguard.
