Dual carb manifold
getafix
Dual carb manifold
Post by getafix » Fri 04 May 2018, 10:29
Dual weber - downdraft - setup wanted for ford V6. As complete as possible. Was this the interceptor configuration??
I'm not a complete idiot, some parts are missing 8O
Ford Sierra V6
AC Cobra V8
Shaunp
Re: Dual carb manifold
Post by Shaunp » Mon 07 May 2018, 16:02
The interceptor had triple carbs. The twin carb manifold you can get from Roland manifolds in cpt.
Sent from my SM-G935F using Tapatalk
Magic happens.
getafix
Post by getafix » Tue 08 May 2018, 18:41
Had a look at the Roland website. Picture on there is scary - manifold quality looks to be under par. VW forum reckons to stay away from them. Burton power in UK has got a nice setup but ZAR/GBP exchange rate ruled that out very quickly. :evil:
Ford Sierra V6
AC Cobra V8
Post by ZA Perana » Tue 08 May 2018, 21:12
I have seen a few roland manifolds and the quality is ok, they are well experienced with Ford V6's.
Shaunp
Post by Shaunp » Wed 09 May 2018, 18:56
Interceptor kit is pricey. You also get the xocet/Holley carb with muscle intake as well the ego set up.
Magic happens.
goddard
Post by goddard » Thu 10 May 2018, 20:54
If you looking to spice up a pretty standard 3l v6, go with the dual carbs (the Roland manifolds are tried and tested) a good alternative is the single 4 barrel Holley as found on the Xocet. (the Xocet made more power than the Interceptor with its triple carbs)
The triple carbs was not very well thought out, they never work well on a standard 3l, but, they CAN work well on a big bore stroker v6...
back in the day I used to run against Interceptors with my Cortina Xle (with twin carbs and branches) don't think any interceptor crossed the line within 4 cars lengths behind me.
Shaunp
Post by Shaunp » Fri 11 May 2018, 06:31
Shaunp wrote:Interceptor kit is pricey. You also get the xocet/Holley carb with muscle intake as well the ego set up.
" efi"
Magic happens.
getafix
Post by getafix » Thu 17 May 2018, 19:41
EFI would be nice to have. Any one there manufacturing EFI manifolds? :?:
Ford Sierra V6
AC Cobra V8
Post by RASSIE » Fri 18 May 2018, 07:22
Balanced V6, gas flow heads, 79 cam, 4 barrel intake and 390 Holley and you run like the wind!!
