How does one remove...
goddard
Post by goddard » Tue 17 Jul 2018, 09:03
How does one remove... the ignition of a 74 Ranchero (column shift auto) Damn, I tried, :x and I don't want to eventually break something. TIA.
BigBerns
Re: How does one remove...
Post by BigBerns » Thu 19 Jul 2018, 01:17
Leaving this here to see the answear haha
Post by ters » Thu 19 Jul 2018, 05:55
How about a quick introduction here https://www.africanmusclecars.com/forum ... m.php?f=41 before you return please? Tell us about yourself and your car/s?
goddard
Post by goddard » Thu 26 Jul 2018, 06:14
Hi, removing the ignition must be an impossible task that nobody on the forum has tackled? Mmmm, I will leave the post here, hopefully someone knows.
Punch
Post by Punch » Thu 26 Jul 2018, 12:46
Any chance of a picture? Some ignition switches were mounted using snap off heads leaving a mushroom head behind which cannot be drilled.
Nobody is going to admit they used a angle grinder & 4lb hammer. :oops: :oops:
Johann66
Post by Johann66 » Thu 26 Jul 2018, 13:50
My Opel Rekord uses the following procedure.
Disconnect the battery
Remove the steering
Remove securing exterior screws holding the ignition
Remove the interior assembly screws working from the front
The loose assembly can then be separated and removed.
Check how the wiring and plug is unplugged.
The Opel has a closed column cover that cannot give you access to the interior!
Sterkte!!
goddard
Post by goddard » Fri 27 Jul 2018, 09:38
I cannot get the steering ignition cover off... it has no screws, I am quite mechanically minded, but this has stumped me.
Post by jlebenon » Fri 27 Jul 2018, 18:57
The key needs to be in the "on" position
Johann66
Post by Johann66 » Sat 28 Jul 2018, 18:07
Key in on is correct! Else the steering lock will not disengage :D This is wat is preventing you sliding out and over the column!!
Post by RASSIE » Sun 29 Jul 2018, 05:47
Ters have ask " quick introduction please". Then we will assist! :D
