Mk1 Ford Granada Chassis Number
Granada75
Post by Granada75 » Wed 23 Oct 2019, 10:48
Hi,
Would anyone be able to tell me where I can find the stamped chassis number on a 1975 Ford Granada XL on the body shell?
Thanks in advance
Archie
74 Granada Ghia
Re: Mk1 Ford Granada Chassis Number
Post by 74 Granada Ghia » Wed 23 Oct 2019, 19:52
You will not find any numbers on an SA made Granada. The only ID you have are the plate on the right hand side on top of the slam panel.
Granada75
Post by Granada75 » Wed 23 Oct 2019, 20:43
Thank you for that information it’s much appreciated
Granada75
Post by Granada75 » Wed 23 Oct 2019, 20:44
Would you be able to help decode this plate?
Post by IndianaJones » Fri 25 Oct 2019, 16:45
I can’t be certain, as I don’t have the decode info for Granada’s, but an educated guess at decoding the data plate as follows:
O = Source ~ The “O” is odd, could be correct or perhaps mis-stamped from the factory, but it is usually “C” for Ford of Britain, or "E" for Ford of Germany
X = Assembly ~ South Africa (Neave Plant)
GF = Granada 4 door Sedan
R = Year of Assembly ~ 1975
K = Month of Assembly ~ February
61087 = Serial Number
199963 = Sido number
M = Engine ~ 3.0L V6
C = Trans ~ Again the “C” is odd, the code is usually N for the 4 speed Manual, and B for the Floor Shift 3 Speed Automatic, don't know whether there was perhaps Column-shift Granadas built?
blank = Diff ratio code (don’t have that info, and this is usually a numeric code)
Trim code
0 = Monotone
F = Tan interior
Paint Code
0 = Monotone
Q = Sahara Beige
Like mentioned before I don't have Granada decode info, but there was some similarities in the Ford coding of the time.
I see in your other post, your car has a vinyl roof, this is also odd, considering the double character trim code, usually a factory vinyl roof car would have a triple character trim code, with the first position referencing the vinyl roof colour.
Granada75
Post by Granada75 » Fri 25 Oct 2019, 20:11
Thanks for the information.
In regard to the vinyl roof I was told that it was a later addition from a dealer rather than from the factory.
74 Granada Ghia
Post by 74 Granada Ghia » Mon 02 Dec 2019, 15:13
The C is C4 auto( US made same as in the Perana but with a different bellhousing) and D is C3 auto. This is euro spec codes but if the Granada from 72 - late 73 it has a C4 box marked C on the plate.
Users browsing this forum: No registered users and 13 guests
