1958 Chevy Apache unfinished Project
- Chassis has been sandblasted, primed and painted
- Cab, body panels & parts - sandblasted
- rust repaired
- primed
- steel rear steps & fenders
- need new load bin
- windscreen not cracked
JAG Suspension
- Front suspension fitted
- Rear suspension assembled
- sandblasted
- primed and painted
- overhauled with brand new Jag parts,
- ball joints
- Tire rod ends
- bushes, upper & lower
- wheel bearings front & rear
- shocks
- 2x coil rear springs
- 4 x brake discs
- all brake pads
- all rear U joints
- bearings front and rear
- Callipers need to be recon
TYRES & Rims all New x4
- 265/65/R20
- Torque thrust rims
- billet steel 20mm spacers
- M14 studs
- chrome wheel nuts
ENGINE
- Chev 454 Gen5
- TH700R4 box
- GM forged pistons
- STD hastings chromoly rings
- ACL Big ends and mains
- Comp 268H cam and lifters
- S.A gear double row timing chain
- Melling M55hv oil pump
- Fel Pro gaskets
- Pro Comp intake manifold
- Holly 770 street avenger carb
- Pro form HEI 10.5mm plugs wires
- Stainless steel mid length headers
- airtex water pump
- chrome alternator with pulleys and brackets
- 14" chrome air cleaner
- accelerator bracket
- TV cable linkage
- block was honed and measured
- crank micro polish
- heads recon and pressure tested
- block cleaned and painted
PARTS
Most still in boxes sealed
- 6 gauge set GPS speedo
- electric window kit
- Chrome tilt column shift steering
- aluminium radiator
- 2x oil coolers
- 16" S curve 3000cfm electric fan
- 15 circuit wiring kit
- stainless steel fuel tank 100LL fits in chassis
- stainless radiator hoses
No papers
Chassis, Cab, body panels with jag suspension,
rims and tyres & windscreen R110k
Or everything for R220k
Contact 072 303 0774 for viewing & more info
Situated in Klerksdorp area, North West Province
Can send more pictures upon request
1958 Chevy Apache unfinished project
- ● All adverts must include pictures and a price. This is not a bidding site.
- ● Please respond to enquiries, if you don't respond your add will be removed.
- ● Please change an item heading to SOLD when it is sold.
- ● Members are allowed 12 adverts per year to make sure the forum stays an enthusiast platform.
- 8ED3ACC5-8411-4E30-8653-9EB5537A7F50.jpeg (137.9 KiB) Viewed 1499 times
- EEE88BBF-C429-454C-A3CB-33AC4EC65B94.jpeg (123 KiB) Viewed 1499 times
- 476FEBA4-B208-49D0-A4FC-D5014CC33BED.jpeg (89.44 KiB) Viewed 1499 times
- FFC6C5B4-B198-4BF9-813A-1AA4C96D7AE1.jpeg (86.13 KiB) Viewed 1499 times
- 6CA3613C-F5E0-44FA-B0EA-94C1A54ACF66.jpeg (95.65 KiB) Viewed 1499 times
- 41BC02FE-DAF9-45FD-A6B9-ABF18A89454F.jpeg (136.39 KiB) Viewed 1499 times
- 7CEDDFB0-5454-460B-B781-642CEDC1D6A3.jpeg (114.7 KiB) Viewed 1499 times
- 4D156F1F-EBE3-4598-968B-597E50059614.jpeg (91.39 KiB) Viewed 1499 times
- F0B92B05-8FCC-41F9-8984-B7BF92BFE74A.jpeg (112.89 KiB) Viewed 1499 times
- 820F67DB-3B68-467D-8B1E-C4B864DA5F0E.jpeg (106.13 KiB) Viewed 1499 times
- E288CEC8-54BC-4794-A5C2-293910DFFB09.jpeg (90.13 KiB) Viewed 1499 times
- 0A52A6BA-F116-4CF7-9566-5835EBF91BEB.jpeg (98.48 KiB) Viewed 1499 times
- 7FEB1DCC-BCC3-4AB6-BE4C-0EB63CDAEFC3.jpeg (215.81 KiB) Viewed 1499 times
- C7090490-79C2-431C-81ED-B5223CAD52BC.jpeg (129.95 KiB) Viewed 1499 times
- B6F39B98-EFDD-4450-AF6A-42A35AE81F90.jpeg (93.07 KiB) Viewed 1499 times
- EEEC8A2E-AFF8-43B5-9EF4-43D0F68B2EE4.jpeg (84.79 KiB) Viewed 1499 times
- 531BDA79-3098-476E-B1E1-170F63EC9F46.jpeg (65.87 KiB) Viewed 1499 times
- 6E534F4E-FDBD-469E-8404-FE1A55B2241F.jpeg (104.62 KiB) Viewed 1499 times
- 88682EF5-E703-4C1B-99D1-0ABC17E14C1C.jpeg (107.61 KiB) Viewed 1499 times
Re: 1958 Chevy Apache unfinished project
Lyk baie mooi!!
Kan ek maar Sondag kom kyk please
Dankie
Dankie
Sold Sold Sold thank you Turbine!!
